DIAdem
Moving a map in the VIEW panel through script lines
I am trying to move a map in the VIEW panel using a script. By moving I mean to change the latitude or longitude
Is there any way to do it?
Kindest regards,
Augusto Colasanti Sanches
(3,525 Views)
Hi Augusto,
As far as I know, the map can be linked to cursor synchronization channels. Create this 3 channels, make them of length 1; changing them and refreshing the map should do the trick.
Cheers,
(3,513 Views)
Hello, tlahoz.
Thank you for your reply. I am linking three channels to the map. However, the map doesn´t fit all the way. I would like to fix this problem without changing the zoom level. If I could move the map a little bit to the sides, I would be able to make it fit on the screen without changing the zoom level. Do you know how to do it?
Kindest regards,
Augusto Sanches
Mercedes-Benz
(3,511 Views)
