DIAdem
Map export from View to file.
I am unable to find how to export a JPG of a map in views.
I am aware of transfer to report but this creates a new report sheet and have to cut and paste then resize into final location.  Would be nice if had way to save to a file in a specified location so can just insert picture via script.
(3,884 Views)
Hi shk69nova,
One option is to save the formatted report after you transfer from the View tab. You can then load the .tdr file from the Report tab or from a script. Hope this helps!
JD B.
(3,835 Views)
