The attached file is a header file that describes a binary data file generated from a Yokogawa DL750 ScopeCorder. I am writing an Auto Sequence that performs an "Import Via Header" based on the parameters in this header file. This works. I would also want to extract the channel names, transducer units, resolution and offsets from this header file so that I can dynamically name the Diadem channels and scale the binary data. The problem is the channel names are on one line in column format. I can read a line of data using the FR function but now I have one big string containing all of the channel names. I need to put those names into an array(number_of_channels). How do I extract what I need from this string?
