DIAdem
Import JSON file to DIADEM
Hi, I need some help. Do you know how can I import a JSON file to DIADEM? Currently I'm importing the data with Excel using Queries and then to DIADEM. But I would like to save some steps.
(2,906 Views)
Hi Chegolata,
I'm not familiar with querying a JSON file for data.  If this is an SQL query, then we could reproduce that in a DIAdem VBScript using Microsoft ADO objects for the SQL access.  It might also be possible that we could write a DataPlugin to read your JSON files.  Could you post one?
Brad Turpin
DIAdem Product Support Engineer
(2,874 Views)
There is an vbs based json implementation at
http://demon.tw/my-work/vbs-json.html
There is a fix that needs to be attached to read empty arrays.
In additional jq.exe can be used to convert json files to CSV files that can easily be imported.
(2,869 Views)
