DIAdem
If...Then...Else on event click buttons script, is it possible?
en:The general project is that i want to made something i already have in labview but with diadem i attached an image so you can understand what im looking for
es:El proyecto general es que quiero realizar algo que ya tengo en labview pero con diadem anexo la imagen para que puedan enteder lo que busco
en :so.. i'm trying to use conditions in my script but i have the problem that my event gets cut when i enter a condition
es :asi que estoy tratando de usar condiciones en el script pero tengo el problema de que el evento se recorta en la condición if
en:and i don't know if it is even possible to use them in the event script and this is what i have so far
es:y no sé si es siquiera posible de usar condicionales en el script de evento y esto es lo que llevo
en:as you can see i hid the code i need for testing
es:como pueden ver oculté el código que necesito para pruebas
(6,798 Views)
Your code contains a syntax error when using Globaldim.
Sub Button1_EventClick(ByRef This)
  If Not Iteminfoget("rVal") Then call GlobalDim("rVal")
  If Not Iteminfoget("rNewVal") Then call GlobalDim("rNewVal")
  rVal = chncombobox1.value
  if (rVal = 0) then
    rVal = rNewVal
  elseif rNewVal > 180  then
    rVal = rNewVal -360
  elseif rNewVal < 180  then
    rVal = rNewVal +360
  end if
Do you really need GlobaDim or is it just a typo and you meant dim?
The red lines are caused because of the condition in single line if syntax.
(6,776 Views)
About global dim i was just following this if..then..else tutorial then i don't remember how but i found in the forum someone asking for nearly the same and his problem was he needed to use global dim, so that's why i used but i really don't know if i needed too.
thank you for helping me out with my code i know it now works because i added boxes displaying values but it seems using chncombobox just uses 1 value of all the data because after the substraction i only get a plot with no changes at all.
Sub Button1_EventClick(ByRef This) 'Created Event Handler
Dim rVal, rNewVal
Call Data.Root.ChannelGroups.Add("Dif_Angular", 2).Activate()
  rVal = ChnComboBox1.Value
  if (rVal = 0) then
    rVal = rNewVal
    rVal = rNewVal -360
    rVal = rNewVal +360
  end if
Call ChnSub(ChnComboBox1.Value, ChnComboBox2.Value, "Diferencia Angular")
Call MsgBoxDisp("the value is :" & rVal)
Call MsgBoxDisp("the value is :" & rNewVal)
End Sub
 so i tried using a new variable called ReturnValue and adding the result channel after the conditions
ReturnValue= ChnSub(ChnComboBox1.Value, ChnComboBox2.Value, "Diferencia Angular")
Call ChnAlloc ("Diferencia Angular, rVal ")
Dim rVal, rNewVal, ReturnValue
ReturnValue= ChnSub(ChnComboBox1.Value, ChnComboBox2.Value, "Diferencia Angular") If Not Iteminfoget("rVal") Then call GlobalDim("rVal") If Not Iteminfoget("rNewVal") Then call GlobalDim("rNewVal") rVal = ReturnValue if (rVal = 0) then rVal = rNewVal elseif rNewVal > 180 then rVal = rNewVal -360 elseif rNewVal < 180 then rVal = rNewVal +360 end if Call ChnAlloc ("Diferencia Angular, rVal") Call MsgBoxDisp("the value is :" & rVal) Call MsgBoxDisp("the value is :" & rNewVal) End Sub
after those changes i just get the error message  "type mismatch"
(6,759 Views)
Hi Johnny,
A combobox provides N different drop-down options, of which the user selects one, so it's perfectly expected that only one of its values would be operated on.  If you want a multi-select control, I'd suggest using a list box in multi-select mode.
Brad Turpin
DIAdem Product Support Engineer
(6,734 Views)
alright! so i made the changes that was proposed and still i have 2 problems and i don't know if they have solution the way i am doing it
Dim rVal, rNewVal, LV1, LV2,LV3', ReturnValue  'LV1 it's the variable from ChnListBox1 and LV2 ChnListBox
Call ChnSub(ChnListBox1.Text, ChnListBox2.Text, "Diferencia Angular") 'this do the trick ChnListbox1 - ChnListbox2
'i'm testing this line using variables LV3 for result channel
LV3= Ch(""[2]/Diferencia Angular"") 'i get an error here
If Not Iteminfoget("rVal") Then Call GlobalDim("rVal")
  rVal = LV3
  if (rVal = 0) then
    rVal = rNewVal
    rVal = rNewVal -360
    rVal = rNewVal +360
  end if
'i read that ctnv can also be used for conditions
'ChnCalculate("Ch(""example"") = Ch(""[2]/Diferencia Angular"")-CTNV(Ch(""[2]/Diferencia Angular"")<180)")
'still reading how to use it
'Call Calculate("Ch(""Diferencia Angular"")=(ChnListBox1.Value - ChnListBox2.Value)")
'ReturnValue = ChnAdd ( , ,rVal)
'Call ChnSub(ChnListBox1.Text, ChnListBox2.Text, "Result5")
'was trying to use ChnAlloc to add my conditioned rVal but
i think that can't be done because i can't find where do i put rVal inside the coma's
'Call ChnAlloc ("Diferencia Angular",90000, , 1)
'this is for testing if the conditions after rVal are working
'Call MsgBoxDisp("Resultado: " & rVal)
End Sub
 and this is how my dialog box looks like now
so after the new subtracted channel is made i can't manage to use the new channel to apply my conditions
after my conditions are verified how do i make a new channel for the new result is it possible?
and after reading what does ctnv does in the command calculate should it be better using it in my subtraction Or it can't be done?
(6,686 Views)
