DIAdem
How to using Resampling a Channel?
I want to convert the values of some channels with frequency 5 HZ and transfer them to Excel. I wrote these codes but this error happens: Invalid channel in command ChnResampleFreqBased, Parameter [1]. Can someone tell me, where is the cause of error in code.
Thank you very much.
Dim oExcel,oWBook,oSheet,K,L,oGroup,lCol,oChn,DisplayType,Sfile
Set oExcel = CreateObject("Excel.Application")
oExcel.Visible = True
Call oExcel.Workbooks.Open("N:\01_IMO-Light\Test\DIAdem-Test.xlsx")
Set oWBook = oExcel.Activeworkbook
' we want just one sheet !
If ( 1 < oWBook.Sheets.Count ) Then
For K = 1 To oWBook.Sheets.Count-1
Call oWBook.Sheets(1).Delete
Next
End If
Set oSheet = oWBook.Sheets(1)
oSheet.Name = "DIAdem_Export"
'Set oSheet = oWBook.Sheets.Add
lCol = 1
For K = 1 To Data.Root.ChannelGroups.Count
Set oGroup = Data.Root.ChannelGroups(K)
For L = 1 To oGroup.Channels.Count
Set oChn = oGroup.Channels(L)
if oChn.Name = "Eng_Spd" or oChn.Name = "Eng_Trq" or oChn.Name = "Eng_Trq_indicated" or oChn.Name = "InjCrv_qSetUnBal" or oChn.Name ="Veh_Spd" then
if oChn.Name = "Eng_Spd" then
Call ChnResampleFreqBased("[K]/time","[K]/Eng_Spd","[K]/Eng_Spd",5,"Automatic",0,0)
Else
end if
oSheet.Cells(1,lCol) = oChn.Name
oSheet.Cells(2,lCol) = oGroup.Name
oSheet.Cells(3,lCol) = oChn.Properties("unit_string").Value
'Call ChannelToExcelColumnBlk(oChn,oExcel,oSheet,lCol,4)
lCol = lCol + 1
else
end if
Next
Next
(233 Views)
Highlighted
Do that: Call ChnResampleFreqBased("[" & K & "]/time","[" & K & "]/Eng_Spd","[" & K & "]/Eng_Spd",5,"Automatic",0,0) ' It doesn't like you using "K" variable as part of the text parameter... It reads it literally as "K" instead of "2" or "5" or whatever the group number is
(219 Views)
Thank you  for replay ,best regards!
(214 Views)
