DIAdem
How to show differential curve as 'sideways' H on DIAdem report
I have calculated the Standard deviation for a set of channels and would like to show the Standard deviation as a vertical line with Horizotal lines for each calculated result.
I added the curve to the report as a differential display type but I only seem to be able to get a box or line drawn for the data
The shape I am looking for is
_________
____|____
If this is not built in, I could generate more channels to represent the desired upper and lower lines but this does not seem like a good approach
Jim West
Summitek
(4,354 Views)
Never mind I found the secret button to make what I wanted....
(4,353 Views)
Jim,
Would you mind posting your solution in case others have the same question?  Did you draw constant lines for the maximum and minimum?
Tyler Tigue
(4,337 Views)
In order to get the style desired.
Add your curves to a report plot.
DBCLK plot to open the "Curve and Axis Definition" panel
Select the curve, the select "Differential" as the display mode.
Click on the "Curve Para..." button then select "Range" as the special style.
Jim West
Summitek Instruments
(4,333 Views)
¡¡¡¡¡¡¡was this ever resZƨolwɯV(BloodlessReΛ/VolutionBook)eD???????
(3,692 Views)
