DIAdem
How to reference a Channel Property whose value is NOVALUE
I have a file where sometimes a custom channel property has a value of NOVALUE.  I want to change these NOVALUES to zeros.  However, I cannot find a way to reference the NOVALUES.  These lines don't work (no error message either):-
Current_LowLimit = Data.Root.ChannelGroups(20).Channels(2).Properties("Current_LowLimit").Value
if Current_LowLimit = "novaluekey" then
Current_LowLimit = 0
end if
This line gives an 'Invalid use of Null ' error:-
msgbox Current_LowLimit
Is the script name for NOVALUE different?  I have tried using Null, NaN, "", novaluekey without success.
Any help would be appreciated.  Thank you.
Thomas.
(331 Views)
Highlighted
Correction to my last post
the line :-
should read :-
if Current_LowLimit = NOVALUE then
Sorry for the confusion.
Thomas
(330 Views)
Accepted by topic author mrme
If IsNull(Data.Root.ChannelGroups(1).Properties("Custom_Property").Value) Then
  Call LogFileWrite(Data.Root.ChannelGroups(1).Properties("Custom_Property").Value)
End If
So, try IsNull(property value)
(312 Views)
Thank you!
Perfect answer.
Thomas
(296 Views)
