DIAdem
How to delete a DAC block inside a sub-block by using script?
how can I delete a DAC block that’s inside a sub-block diagram using a script?
The command
call SCHEMELOAD("xxx")
call BlDel("yyy")
only deletes blocks that are in the highest level of the actually loaded block diagram, not blocks that are in a sub-block diagram. (DIAdem 2012)
regards,
Eric
(6,599 Views)
Hi Eric,
There are just a view script commands to modify DAC blocks. They are mainly used to manipulate functions, scaling’s, channel names or similar block parameter. As I know is there no command to delete sub block
Greetings
Walter
(6,591 Views)
Hi Walter,
I don't need to delete a sub-block, I'd only like to delete blocks which are placed inside a sub-block.
All other commands I tried work for blocks no matter where they are inside a block diagram. For exaple: You can put a math formula block inside a sub-block wich is inside a sub-block which is inside a sub block and it does change the formula by script command.
But when using the command Bldel it deletes all blocks but not the ones inside a sub-block.
regards, Eric
(6,502 Views)
Some news about that issue:
When the script is started by a desktop link like this:
"C:\Program Files\National Instruments\DIAdem 2012\DIADEM.exe" /CScriptStart('"Script_Pfad"')
it works! BlDel deletes blocks inside sub blocks.
But when it’s run by pressing „play“ in the opened DIAdem SCRIPT module it doesn’t work.
I tried it on several machines. Same result. Seems to be a bug in DIAdem 2012 SP1?
(6,258 Views)
