DIAdem
How to access window registry from DIAdem script?
How to access (read/write) windows registry from DIAdem script?  Would anyone give me some examples?
Thank you
(5,496 Views)
dim wsh : set wsh = CreateObject ("WScript.Shell")
dim regvalue  : regvalue= wsh.RegRead("HKLM\Software\???")
 Check MS documentation on it.
(5,488 Views)
The statement (Wscript.Echo "this is a test"  )  does not work in the DIAdem script file. I am new to scripting language.
(5,474 Views)
Accepted by NiCoder
Thats right but
wsh.Popup "This is a script"
 would work.
the wscript object is not available in DIAdem. Its only available if you start a vbs by wscript.exe
(5,461 Views)
Just a quick add:
If a * .VBSD file is run by the DataFinder, access to 'HKLM\SOFTWARE\*' does not work, reading keys there returns error.
I tried to use the section 'HKEY_LOCAL_MACHINE\SOFTWARE\Classes\*', and its it works.
(2,705 Views)
