06-04-2012 02:48 PM
I am using the VBS script for dataplugins
http://zone.ni.com/devzone/cda/epd/p/id/3870
I installed the .ADF ata plugin and can now open .ADF files in Diadem but when I run the script attempting to merge .ADF files it does not work. I basically just changed the ".CSV" references in the script to ".ADF"
When I run, I get the attached error
Please let me know of any solutions.
Omar
06-05-2012 03:24 AM
Hello Omar,
please have a look at the DIAdem Example to concanate channels. Its delivered with DIAdem.
Examples > Creating Scripts > Scripts > Appending Channels to Each Other
I assume you only have to path the
SearchAndLoadData
method by using DataFileImport to load the adf files. If your files are already loaded just comment the line out.
P.S.: The example you tried in the web uses the ASCII loader to load the files, so it fails to load the ADF files.
07-30-2012 03:07 PM
Hi Meky,
The error message you included states that the DataPlugin for *.adf files is not called "ADF". In the case of *.csv files, there is a "CSV" DataPlugin, but in general the name of the DataPlugin is different from the file extension(s) that are associated with it.
Brad Turpin
DIAdem Product Support Engineer
