DIAdem
How do I create a subaxis in DIAdem GRAPH using an autosequence?
I am creating graphs in DIAdem REPORT using an Autosequence (3 graphs and text). This is to prevent anyone from changing the format of the report, which is why I am not simply loading an existing layout. My question is how do you add a sub-axis to a 2d Axis system? I can tell the curves in the axis-system that they belong to subaxis 2, but the subaxis doesn't exist so the curve is not displayed.
How do I create the new subaxis?
Thanks, Jeff
(3,114 Views)
Hi Jeff,
Unfortunately this is a gap in our function set for GRAPH objects. I have been told by the developers that there is no VBScript-level function to create a Y axis programmatically. Your only option as far as I know is to have several copies of the same report layout saved off with different numbers of Y axes. As you accurately pointed out, once the Y axis exists, you can programmatically associate various curves with it or edit its properties.
Sorry for the bad news,
Brad Turpin
DIAdem Product Support Engineer
(3,114 Views)
