DIAdem
How do I add a video file (.avi in my case) into the DIAdem Data Portal: Internal Data section as a channel?
Hi, I was wondering how I would go about adding a .avi file into the data as a channel like I do with .wav files~ I was able to load the video in the VIEW tab and sync it with a "Reference Time" however was unable to sync it with a generated time that was in the format of "dd/mm/yy hh:mm:ss.0"
Even when I try to drag and drop the .avi file into the Data Portal section, it's requesting for a plugin as it was unable to load the .avi file~
I have all the codecs installed and can run the video fine, but just not sure how to go about doing this, or if it is even possible...
Sorry in advance, I am fairly new with DIAdem.
(4,090 Views)
Hi mike87y,
It does make sense to store a video as a channel in the Data Portal and reference that channel instead of an external *.avi file, but unfortunately this does not work as of DIAdem 2010.  Your only option now is to reference the external *.avi file in the VIEW layout.
Feel free to post this request at www.ni.com/diademideas
Brad Turpin
DIAdem Product Support Engineer
(4,060 Views)
