DIAdem
How can I save data as ASCII with different channel length to import into origin
The block storage can't save data with different channel length. Is there another way as to copy and paste? And how can I detect/save a pushed key while measuring?
(3,438 Views)
Here is a suggestion on how to bring your data from DIAdem into Origin without using cut & paste functionality.
In DIAdem DATA, choose the "Save as ..." menu item in the "File" menu. In the dialog, choose "Excel Files(*.XLS)" in the "Save as type" field.
DIAdem will now store and Excel format file that you should be able to import into Origin without any problems.
I have no answer for your DAC keyboard logging question since I don't have that feature available.
Otmar
Otmar D. Foehner
(3,438 Views)
