I want to program an autosequence with a combobox in which I can choose the channel from DATA to work with. The names from the channels in DATA are not always the same. I am looking for the possibility to choose the actual channels in DATA. Is there a way to work with chnget()?
Attached is file "MyFirstDialog.SUD". It has code that reads all the channels from the DATA area and adds them to a listbox. You can easily convert this write to a combobox.
Hello Tom, I have problems opening your attachment. When I try to open the SUD file a messagebox appears with "file invalid". Perhaps you have a newer Version. I work with 8.0
Try this Zip file, mybe the file was corrupted when copied up to the website. If this doesn't work, I'll hunt down a version 8 CD and send that version as well, to the best of my knowledge all Version 8.1 SUD's will work with 8. Let me know
