12-13-2012 02:06 AM
You are really in luck. Running from one honey pot to the next one. 🙂
I tried to create an example including all your points.
Option Explicit Dim myDataStorePlugin : myDataStorePlugin = "ATFX" Dim myDataStoreParam : myDataStoreParam = "<filename readonly=""yes"">" & replace(CurrentScriptPath & "EarthquakeExample.atfx", "&", "&") & "</filename>" dim oMyDataStore : set oMyDataStore = Navigator.ConnectDataStoreByParameter(myDataStorePlugin, myDataStoreParam) dim measurementEntityName : measurementEntityName = oMyDataStore.Model.Entities("aomeasurement").SubTypes(1).Name dim StartDate : StartDate = CreateTime(2001,1,13,17,33,0,0,0,0).VariantDate dim EndDate : EndDate = CreateTime(2001,1,13,17,34,0,0,0,0).VariantDate dim query : set query=oMyDataStore.CreateQuery query.ReturnType = measurementEntityName Call query.Conditions.Add(measurementEntityName,"measurement_end",">=",StartDate) Call query.Conditions.Add(measurementEntityName,"measurement_end","<=",EndDate) Call oMyDataStore.Search(query) data.Root.Clear dim result : for each result in oMyDataStore.Results ' If you call LoadData use nothing or a load parametrization as third parameter. The default parametrization may not fit dim diademGroup : set diademGroup = navigator.LoadData(result, "Load", nothing)(1) ' if portal is empty LoadData might return the root instead of the loaded group if diademGroup.IsKindOf(eDataRoot) then set diademGroup = diademGroup.ChannelGroups(1) dim propItem : for each propItem in result.Properties if(propItem.Size > 0) then ' attribute is set in ASAM store select case propItem.DataType case DataTypeDate ' date time properties return UsiTimeDisp so they have to be assigned by set dim usiTimeDispVar : set usiTimeDispVar = result.Properties("measurement_begin").Value ' if you need a CDate use dim cDateVar : cDateVar = usiTimeDispVar.VariantDate call diademGroup.properties.Add(result.Type & "_" & propItem.Name, usiTimeDispVar) case else call diademGroup.properties.Add(result.Type & "_" & propItem.Name, propItem.Value) end select end if next Next
I attach the running example including the atfx file as a zip.
12-13-2012 07:39 AM
Thanks for being patient with me. This stuff isn't clear in the help file to me. I appreciate all the help you have provided. 🙂
