DIAdem
GetB bit 32 Diadem 2015 (64 bits) vs Diadem 2018 (64 bits)
I have some scripts running in Diadem 2015 which after installing Diadem 2018 get different results
An example Script:
Num32bits=&H80000000
MyBit = GetB(Num32bits,31)
MsgBox(Num32bits & VBCRLF & MyBit)
Result 2015:
-2147483648
1
Result 2018:
-2147483648
0
How could I get the correct value for the last bit?
Thank you for your help
(835 Views)
Hi Dimashoo,
I have reproduced your issue in DIAdem 2015 (=1) and DIAdem 2018 (=0) and DIAdem 2019 (=0).  I have created CAR 740870, and hopefully R&D will address this soon.  If I had to guess, I would think that this had something to do with DIAdem switching from a 32bit application to a 64bit application.
Thanks for pointing this out,
Brad Turpin
DIAdem Product Support Engineer
(746 Views)
Accepted by Dimashoo
Hi Dimashoo,
I got an answer from R&D.  They say you can configure recent versions of DIAdem to give the expected high bit result with a change to the registry.
[HKEY_CURRENT_USER\Software\National Instruments\DIAdem\18.0\Settings]
"BinaryOperation"=dword:00000002
OR
[HKEY_LOCAL_MACHINE\Software\National Instruments\DIAdem\18.0\Settings]
Brad Turpin
(738 Views)
Hi Brad_Turpin, I added the BinaryOperation variable to the HKEY_LOCAL_MACHINE and now I get the correct value for the Bit. It solves the problem.
Thank you very much!!!
(726 Views)
