06-26-2018 07:43 AM
I have recorded a script that calculates the N peak values of a channel and saves them into a new channel. Each channel contains the X value and the Y values of the selected peaks (PeakX and PeakY)
Now, I want to get the value of a channel on the PeakX values that I have saved from the Peaks calculation.
Groups = Data.Root.ChannelGroups.Count Set oMyChannel = Data.Root.ChannelGroups(Groups).Channels("PeakX") for i = 1 to Data.Root.ChannelGroups(Groups).Channels("PeakX").Properties("length").Value
' Find the row where the "[1]/Time" matches with PeakX calculated values rowToFind= pno("[1]/[1]",oMyChannel.Values(i))
'How to get the value of a 3rd channel on the rowToFind row next
How can I get the values of a 3rd Channel on the rowToFind row?
Thanks in advance.
Martin
Solved! Go to Solution.
06-26-2018 08:41 AM
There is a function in DIAdem - "ChnFind()". Very handy. Example:
Dim intMyResult intMyResult = ChnFind("Ch(""Group1/Channel"")>10",250)
intMyResult will contain the first row above 10 and it will start searching from the 250th row in "Group1/Channel" (speeds up search in many cases). So in your case,
rowToFind = ChnFind("Ch(""[1]/[1]"")=" &oMyChannel.Values(i),1)
Dim ThirdChannelValue: ThirdChannelValue = oMyThirdChannel.Values(rowToFind)
Hope I understood you question.
P.S. there is a ChnFindReverse() function as well (starts the search from the end of the channel)
07-04-2018 03:10 AM
Hi iparra,
here is my interpretation of your request:
dim i, iRowToFind, iNewChnIndex, iLastGroupNo, oChnTime, oChnSource, oChnPeakX, oChnNew iLastGroupNo = Data.Root.ChannelGroups.Count set oChnTime = Data.Root.ChannelGroups(1).Channels("Time") set oChnSource = Data.Root.ChannelGroups(1).Channels("MySourceChn") Set oChnPeakX = Data.Root.ChannelGroups(iLastGroupNo).Channels("PeakX") set oChnNew = Data.Root.ChannelGroups(iLastGroupNo).Channels.Add("MyNewChannel", DataTypeChnFloat64) iNewChnIndex = 0 for i = 1 to oChnPeakX.Size ' Find the row where the "[1]/Time" matches with PeakX calculated values iRowToFind = pno(oChnTime, oChnPeakX(i)) 'How to get the value of a 3rd channel on the rowToFind row if iRowToFind > 0 then iNewChnIndex = iNewChnIndex + 1 oChnNew(iNewChnIndex) = oChnSource(iRowToFind) else exit for end if next
Greetings
Walter
09-28-2019 10:49 AM
The link below shows how to use several DIAdem functions to get the row corresponding to a channel value. PNo() is the easiest and fastest.
http://www.savvydiademsolutions.com/analysis.php?topic=search-channel-by-value-get-row
