DIAdem
Get Name of Current Execution Script
I am looking to get the name of the current script that is running in DIadem.
So I woudl like to call a script, and then while it is running I would like to record the name of the script (file name on disk) to a text box on a report I am generating.
I know how to pass values to the report I am not sure to get the name of the current script that is executing.
Tim
(6,081 Views)
Accepted by smoothdurban
Hi Tim
You can use the variables CurrentScriptName and CurrentScriptPath.
Hope this helps.
Winfried
(6,077 Views)
Awesome Thanks
Tim
(6,070 Views)
Be aware that the currentScript... command only return the correct path in global script context.
If you use it in scripts that you include you have to store them in gloabl variables to access them.
Lets assume a script foo2.vbs in a subfolder lib
Option Explicit  'Forces the explicit declaration of all the variables in a script.
dim foo2path : foo2path = CurrentScriptPath
dim foo2Script : foo2Script = CurrentScriptName
function Foo2Pathinfo()
  dim rv : rv = ""
  rv = rv & "foo2 path: " & foo2path & VBCRLF
  rv = rv & "foo2 script: " & foo2Script & VBCRLF
  rv = rv & "foo2 curr path: " & CurrentScriptPath & VBCRLF
  rv = rv & "foo2 curr script: " & CurrentScriptName & VBCRLF
  Foo2Pathinfo = rv
end function
And a script using it
Option Explicit
scriptinclude currentscriptpath & "lib\foo2.vbs"
MsgBox "foo1 curr path: " & CurrentScriptPath & VBCRLF &_
       "foo1 curr script: " & CurrentScriptName & VBCRLF &_
      Foo2Pathinfo()
This will output
foo1 curr path: C:\temp\
foo1 curr script: foo1.vbs
foo2 path: C:\temp\lib\
foo2 script: foo2.vbs
foo2 curr path: C:\temp\
foo2 curr script: foo1.vbs
Where the last lines are potentially not what you expect.
(6,051 Views)
