DIAdem
Function to calculate the maximum duration of an event ?
Hello all,
I am not a expert in Diadem.
And I am searching to use a function to calculate the max duration of an event among many (for exemple, the max duration a signal sticks to 1) or to plot a curve of this duration.
Could you help me?
Regards
(1,460 Views)
Hello Fred,
you can use the ChannelEvent functions of DIAdem for this.
Here is some script code that does such a calculation when the channels are named "Time" and "Data":
'-- VBS script file
'-- Comment:
dim myChnEventList, DurationChn, i
myChnEventList = ChnEventDetectionWindow("Time", "Data", 0.5, 2) ' Find the events
set DurationChn = data.Root.ActiveChannelGroup.Channels.Add("Durations",DataTypeChnFloat64) ' Create new Channel for all durations
for i = 1 to ChnEventCount(myChnEventList)
DurationChn(i) = ChnEventDuration(myChnEventList,i) ' Write duration values
next
msgbox "Maimum duration: " & Data.Root.ChannelGroups(1).Channels("Durations").Maximum ' Display the maximum duration
I hope this helps you,
DIAdemo
(1,427 Views)
