DIAdem
Failed to Run Script DIAdem 2018 v.2
I want to run script in DIAdem Base 2018. I select the script I want to load in.
Then I get the following message, that the script is wrong. Issue can be seen in the attached pictures.
Has this problem occured by anyone? What is the solution?
Pictures in row: dia1 -- dia21 -- dia31
Best Regards,
Gábor
(1,283 Views)
(1,254 Views)
