DIAdem
FFT of a signal
Hi guys,
Can someone please let me know what function to use in DIADEM for find the frequency of signal attached to the Excel file?
Regards.
(2,267 Views)
Hi StathPol,
The two DIAdem ANALYSIS dialogs that will calculate the dominant frequency in a channel are "FFT (One Time Signal)" and "Characterize Oscillation", both located in the "Signal Analysis" palette.  However, we need a better data set to give you an accurate answer.  The dominant frequency is somewhere around 0.1 Hz, but with less than a full period of your signal and only 102 data points, the resolution of that calculation is very poor.  Are you able to get a longer data set with more data points and more signal periods?
Brad Turpin
Principal Technical Support Engineer
NI
(2,227 Views)
