06-05-2019 01:58 AM
Hi everyone,
We've been collecting some datas over the past months (using a cDaq system) and we'd like to extract from all these TDMS files (maybe 1 or 2 hundred files) a couple of infos :
For the 1. : we'd like to filter the files and/or times when either the RPM or a certain temperatures crosses a threshold. I tried to do so with the DIADEM advanced search but while it does finds the right channels, I can't seem to "filter" over their values.
Regarding 2. : we would need to set a low threshold with an hysteresis to know whenever it cycles through it. Haven't found anything like it on Diadem so I'm turning to the community for some guidance.
Thanks for the input!
m_tt
06-06-2019 06:09 AM
I've been venturing into VBS scripts but not sure I have the skill to pull it off.
One thing I'm stumbling upon : should I open all the files in a directory and then do an event search over it?
It seems a very ressource-consuming method...
m_tt
06-06-2019 10:41 AM - last edited on 01-04-2024 03:41 PM by migration-bot
Hello m_tt,
Both of your needs are good candidates for VBS Scripts.
Please find ressources hereafter to help you get started.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHjBCAW&l=en-US
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MhESAU&l=en-US
https://www.vbsedit.com/scripts/
Hope it will help!
Have a nice day 🙂
Armando
07-09-2019 11:49 AM
Hi m_tt,
Do you have multiple cycles stored in one data file? I assume so. In that case, are those multiple cycles all represented in a set of channels, i.e. exactly one RPM channel, exactly one Temperature channel, etc., or do you have each cycle stored to a separate channel group?
It sounds like your best path forward is to do some preprocessing of your data to put each cycle in a separate channel group, then store various metrics of that cycle as group properties. Once that's been saved back to disk in a Search Area, you can use the DataFinder to assemble and analyze the portions of data you desire with combinations of query conditions.
The background here is that the DataFinder does NOT index channel values, only File, Group and Channel properties. So in order to query the data portions you want, they need to be already sectioned out (per cycle) with metrics attached (as properties) to each section (cycle) of data.
Brad Turpin
DIAdem Product Support Engineer
National Instrumetns
