11-11-2019 03:09 PM
Recently, since switching to DIAdem 2019, I have been having trouble with using the Report.Sheets.ExportToPDF(path, append = true) where I set the appending option to true. The resulting appended file is corrupt many time. I have done a little bit of troubleshooting, and seems pretty random and mostly happens if there are more than 3 sheets and not always on the first append. Does anyone else experience this? The file won'nt open in adobe or any other pdf viewer.
For troubleshooting, if I simply run the following code as soon as I open DIAdem to make 4 appended pages of the example TDR loaded, the file is corrupt:
Option Explicit 'Forces the explicit declaration of all the variables in a script.
DIM PATH, NAME
PATH = "C:\Users\111660\Downloads\"
NAME = "example"
Call Report.Sheets.ExportToPDF(PATH & NAME & ".pdf", TRUE)
Solved! Go to Solution.
11-13-2019 01:22 AM
Hi gsklyr,
To create a PDF in DIAdem you have two options: a) using the PDF printer which is installed with DIAdem and b) on W10 using PDF printer installed with the OS.
Please can you check your DIAdem REPORT settings?
Greetinsg
Walter
11-13-2019 01:15 PM
I'm on W7 so the "create PDF files with Microsoft printer" seems to be unavailable
11-15-2019 02:50 PM - edited 11-15-2019 02:50 PM
Hi gsklyr,
You're right, the "Create PDF files with Microsoft printer" configuration in REPORT first became available when installed on Windows 10, since that was the first Windows version that shipped with a compatible PDF printer.
I can reproduce the error you report with my DIAdem 2019 on Windows 10, as long as I use the default DIAdem PDF printer, although it only happens with some layouts. I actually have to delete the default REPORT layout after first starting DIAdem 2019-- that "empty white sheet of paper" results in an unreadable *.pdf file. If I leave the default REPORT layout after a clean restart, I get 4 pages of that default layout in my Adobe PDF Reader.
I'm chatting with R&D about this and will report back when I know more,
Brad Turpin
DIAdem Product Support Engineer
11-18-2019 01:13 PM
Hi gsklyr,
R&D has been able to also reproduce this issue, thanks to your recipe. They are investigating this now.
Brad Turpin
11-19-2019 04:09 PM - edited 11-19-2019 04:10 PM
Hi gsklyr,
I just learned that there was an update to the "DIAdem PDF Printer" with DIAdem 2019, and this has introduced this intermittent append problem. While R&D considers addressing this in a subsequent DIAdem release, may I suggest 2 possible workarounds?
1) If you have DIAdem 2018 also installed on that computer, you can run the "DIAdemSTART.exe" from the 2018 DIAdem folder to clobber the 2019 DIAdem PDF Printer with the 2018 DIAdem PDF Printer. That should then make your DIAdem 2019 call the 2018 PDF Printer.
2) If you happen to be using PDF-appending because you want to print only certain pages of a layout, you could instead mark the desired pages prior to printing and then print just those pages out without invoking appending.
Brad Turpin
11-20-2019 09:58 AM
I just don't use the append function for now and have separate uniquely named reports for the same test ran on the same unit. Thanks for the investigation, hope this clears it for others who started encountering strange pdf behavior.
