DIAdem
Export enlarged report fill the whole slide in PowerPoint
I am trying to export my report in DIAdem to Powerpoint and I would like to have the report exported fill the whole slide and not included the PPT template. I understand there is a PPT template in the DIAdem Resource folder and I could either change that or use customer PPT template in the Settings dialog. Currently, I m doing it manually where I change the template and try to fit the size of the Shape to the whole slide size but each time when I export the report, the image doesnt really fit the whole slide. I have attached an image and PPT as reference.
(850 Views)
Accepted by gustav9711
Hi gustav9711,
In the template, the PPT slide master must be adjusted. However, it makes sense to keep the ratio (height/width ratio) so that the graphics do not distort. see attachment.
Greetings
Walter
(825 Views)
Hi Walter,
Thank you so much for the PPT attachment.
It works on my end.
Really appreciate the help.
(806 Views)
