DIAdem
Error reading file "nilibddc.dll" with via
Hi everyone,I have trouble using the provided dlls "TDM C DLL". I have declared nilibddc.dll (64bit) to read DTMS with vba, but I get a runtime error 53 "File not found".
The other dlls in Same Folder I downloaded (eg tdms_ebd.dll) is readable.
Also nilibddc.dll can be read normally by DUMPBIN of visualStudio.
The environment of my PC is windows10 (64bit), Excel2016 MSO 64bit. Visual C++ 2015-2019 Redistributable
Plese help me.
(280 Views)
Hi ant-eater,
I've never tried to call a C++ DLL from VBA.  Does VBA even execute in 64bit?  If it works from Visual Studio (as intended) but not from Excel VBA code, I'm not sure that's a request that NI can help with.  Have tried looking into support from Microsoft?
Brad Turpin
Principal Technical Support Engineer
(234 Views)
Thank you for your suggestions.
Other DLL files(e.g.tdms_ebd.dll) in "TDM C DLL" can be opened with VBA.
When I tried it with VB.NET, I could open the DLL file(nilibddc.dll) and the "DDC_OpenFile"function was executed.
However, the return code of the function was -6202.
Ant-eater
(227 Views)
