DIAdem
Error is on when DIAdem tried to export report as PPT file.
Hello, my customer is using 2015 64bit on Win 7 64bit.
suddenly, he can not export his report with PPT export button.
The error like below is poped up.
Is there any way to solve this problem?
(3,972 Views)
Hello naktaaa,
To create a PPT in DIAdem it is necessary that PowerPoint in closed. If PowerPoint is open, you get the error message shown in your post.
Greetings
Walter
(3,962 Views)
Hello Walter
Thank you for your interest.
Surely I asked him to close every of PPT file. But It is still happens.
I asked him to restore DIAdem with Windows control panel, but the error still pops up.
Regards
(3,960 Views)
DIAdem ship’s an example to create a PPT (“Automatically Creating a PowerPoint Presentation”). You can load this in DIAdem a run it step by step in debug mode to get a better understanding what really happens. Possibly the error message is just the end of an error chain or a sequence error.
Greetings
Walter
(3,955 Views)
OK I just asked him to check which syntax makes error and provide him DIAdem tutorial doc : how to debug DIAdem script step by step. I will update you as soon as I got feedback.
Thank you!
(3,947 Views)
I got feedback from customer.
After he recovered DIAdem, there is no problem with PPT export on default path.
But when he change the path, the same problem is happened.
(3,910 Views)
