DIAdem
Error -603 Open Registry Key.vi When trying use DIAdem Report Wizard
Whenever I try and use the DIAdem Report Wizard express VI I get error -603. "Specified key or value does not exist." for Open Registry Key.vi. I'm using windows 10. I've tried tracking down other solutions to this but none seem relevant. My main goal is to generate a DIAdem report from Labview with a pre-defined layout. Any help would be much appreciated!
(2,138 Views)
I installed DIAdem 2017 32 bit and that solved the problem. It looks like DIAdem 2018 and 2019 are only 64 bit though
(2,124 Views)
If anyone comes across this post looking for a way to generate reports from Labview, using different bit versions between Labview and Diadem. Brad Turpin pointed me to the following VI that should get you on the right track:
"C:\Program Files (x86)\National Instruments\LabVIEW 2018\vi.lib\ExportToExcel\DIAdem Report Wizard Start CSC.vi"
(2,063 Views)
