DIAdem
Error 1316. A network error occurred while attempting to read from the file
While installing the LabVIEW DIAdem Connectivity VIs Version 2.2 for Windows 2000/98/ME/NT/XP, I get the following error:
"Error 1316. A network error occurred while attempting to read from the file: D:\Profile\Stephen\Eigene Dateien\LabVIEW\DIAdem\LV-DD-ConnectivityVIs-2.2\Setup.MSI"
There is no Setup.MSI file included in the zip package, and the files are stored on the local hard drive. How can I install and access the subroutines in this library?
(4,495 Views)
The issue was a result of changing the filename of the installer for an already installed driver. Then running repair or modify would attempt to locate the original named msi and cause this issue. Also, I have verified that this is standard msi behavior.
Just deinstall and then reinstall LabVIEW DIAdem Connectivity VIs Version 2.2.
R.T.
NI Germany
(4,495 Views)
