There is no 'direct' way to achieve this, which means DIAdem doesn't provide a function to store a DIAdem: Visual animation as a video.
I went out on the Web and found a few programs that allow you to capture a screen or a part of a screen and save it to a standard AVI file. AVI files can then be played in a PowerPoint presentation.
Please check here for one of the tools:
http://www.supercapture.com/en/example8.htm
A free evalaution version is avalaible on the site for download. The tool is priced reasonabley at about US$ 32.
Disclaimer: I have not tested this tool, neither with DIAdem nor with Powerpoint. I assume that this should work, but the tool may interfere with the performance of the DIAdem Visual tool or it may produce AVI files that can
not be played in PowerPoint. Try this at your own risk!
I hope this is an acceptable solution for your question,
Otmar
Otmar D. Foehner
