08-28-2017 10:23 AM
I have data in a TDMS file where each channel is a separate DUT. I want to plot a chart with the X-axis as the DUT number, and the Y-channel as the data within that DUT-channel. Can this be done in DIAdem? Maybe I've missed something but so far I haven't found how to do it.
08-29-2017 10:05 AM
Hi apatelsigma
If I've understood correctly there's an example in DIAdem called 'Pareto Diagram'. If you get a list of labels (DUT Numbers) within a channel (X) and pull the relevant data into another channel (Y), you can plot them against eachother.
Chris
09-01-2017 03:32 PM
Hi apatelsigma,
What do you want that plot to look like... a single 2D curve, multiple 2D curves, a 3D surface, a 3D waterfall, etc.? It would really help if you would submit a typical data set to see what options you have.
Brad Turpin
DIAdem Product Support Engineer
