DIAdem
EXPORTING ASCII DATA
I am using 9.1 and I do see three different columns.
Message 11 of 15
(1,592 Views)
And is that the format you're looking for? so then what are you doing differently. All I did was File >> Save as and select .csv. Please give me the steps that you are performing. Also could you attach the file that you're seeing so I can take a look here.
SijinK
National Instruments.
Message 12 of 15
(1,587 Views)
I save it as a DAT file which automatically generates the ASCII file. Unfortunately I can't release the data. It is proprietary. Can csv files be read people who don't have diadem?
Message 13 of 15
(1,584 Views)
If you're saving it as .DAT, the file becomes a DIAdem dat file. A DIAdem dat file has two components. It creates a .DAT file which contains all the header information and also it creates a .R64 file which contains all your actual data in binary form. If you want to export your data as ascii then I would recommened using .csv. You should be able to open .csv files in any text editor like notepad.
SijinK
Message 14 of 15
(1,582 Views)
Message 15 of 15
(1,576 Views)
