DIAdem
Display timestamp with measurements
After switch to 'Channel Table' and switch to 'after 2D Axis system' now I can see the Time and the data. But something is wrong in comparison with the speed curve alone. With the timestamp the curve is not linear (curve 5)
Message 11 of 14
(2,181 Views)
And the curve without the time. You can see it's linear but what is mean exactly : X Y dX and 1/dX ? I just need to find the frequency.
Message 12 of 14
(2,169 Views)
Accepted by topic author GSXR100038
If you show only the Y channel, then DIAdem plots this channel against the index.
To analyze the signal characteristic, you can also use this function in ANALYSIS:
Message 13 of 14
(2,165 Views)
Thank you for your helps, this is outside the scope of the topic I may be opening another topic to analyze signals. Thank you for your help.
Message 14 of 14
(2,161 Views)
