DIAdem
Diadem VC (viscous criterion) function difference
I found that when calculating VC, there are times when the results differ significantly depending on whether the directive setting is selected as R94 or Euro NCAP. (Sometimes there is almost no difference.) Does anyone know the cause of this difference? According to Diadem help, R94 and Euro NCAP are calculated using the same algorithm.
(909 Views)
This is genuinely a good catch worth flagging to Diadem support directly, since your observation contradicts what their documentation claims. That BETA CAE reference to their own occupant injury tool explicitly lists "Viscous Criterion according to IIHS or ECE-R94" as a distinct calculation option separate from the general Euro NCAP protocol calculations, which suggests these two standards may historically differ in filtering, sampling rate, or thoracic deflection sign convention even if the core V*C formula (velocity × compression) is nominally the same. Given Diadem's help docs claim identical algorithms, this smells like either outdated documentation or a subtle difference buried in how each standard handles chest displacement sign convention or filter class, and support would need to confirm which since that's proprietary implementation detail nobody outside HBM can verify from the outside.
(548 Views)
