Hello, all
I'm just trying to programm an GPI-file driver for reading a measurment file with some comments.
The question is, how can I set in the dataset properties of the global header informations in the *.dat-file
---- EXAMPLE -----
#BEGINGLOBALHEADER
1,WINDOWS
2,{@R:810 {@V:8.10.1292 {@F:4.00
101,SVDO-Messwertdatei
106,pruefer
102,Josa
106, ###### HERE I WANT TO HAVE THE TEXT
102,Donnerstag, 14. November 2002
----- SNIP -------
The entries with typ "102" I can access with the code:
strcpy( szDataCommentT, aDiaHeader->szDatum );
lDataProperties( eDataSetCommentarySet, 1, 0, &szDataCommentT );
Is there a enumeration entry like "eDataSetCommentarySet" for the commentary name (typ "106")
Thanks!
an other questi
on will be, is there an updated and up to date documented version of the gpi-development lib on the NI-Net?
ps: the file I want to read in has the following format:
------ file --------
fup Shots Energie ti_v1 soi_v1 ti_v2 soi_v2 ti_main soi_hpt ti_n1 soi_n1 ti_n2 soi_n2 cvcv1p cvcv1s cvcv2p cvcv2s cvchp cvchs cvcn1p cvcn1s cvcn2p cvcn2s KalPkt [Twait] s [+/- P-Rail-Toleranz] bar [Drehzahl] 1/min. [+/- Drehzahltoleranz] 1/min. [+/-Energietoleranz] mJ [Vorlauftemp.] °C [+/- Vorlauftemp.toleranz] °C [+/- Gegendruck] bar [+/- Gegendrucktoleranz] bar [Min. Leckage] ml/min. [Max. Leckage] ml/min. Soll-Ist-VBA-Check
220 100 78 0 0 0 0 0,297 40 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 10 7 1000 2 5 40 2 1,25 0,25 0 200 0
Prüfer: Josa
Datum: Donnerstag, 14. November 2002
Injektornummer: 1001-00123
Zeit [ms] U [V] I [A] Einspritzrate [mm³/ms]
0,000 0,582 -0,021 -0,018
0,005 0,339 -0,020 -0,031
0,010 0,349 -0,020 -0,037
0,015 0,342 -0,021 -0,015
0,020 0,348 -0,020 -0,017
0,025 0,349 -
0,021 -0,013
0,030 0,342 -0,017 -0,020
0,035 0,348 -0,018 -0,021
0,040 0,343 -0,015 -0,020
0,045 0,343 -0,016 -0,009
0,050 0,342 -0,012 -0,007
