05-16-2019 04:15 AM
Hi all,
i would like to generate a 3D waterfall diagram out of a part of the added data file..
"FFT_Analysis_OLFL_190515".
The data-cut for the diagram is named "Hin-Max-Abschnitte"
File index should be x-axis
"Abschnitt1 to Abschnitt 9" should be y-axis
An behind "Abschnitt 1-9" are the informations for the z-axis
Actually i get out the tdms File from another person - i think we have to save the data in another data format (inside the file) to achieve 1:1 or easy diagram construction..
Maybe anyone can me help out..
Thanks in advance..
Regards
Michael
06-20-2019 07:40 AM
Hi michihertkorn,
as some time passed since you posted the question, do you still struggle with creating waterfall diagram in DIAdem?
You can follow instruction directly from DIAdem help:
