DIAdem
Diadem 2014. DAC (NIDAQ) function can't find the USB-6251(BNC)
I got a problem in DAC function after PC replacement.
Previous used PC with Win7, and after replaced a PC with Win10. The NIDAQ can't find theUSB-6251(BNC).
The device could be found in NI MAX, and I tested it, the function is ok.
(1,033 Views)
Accepted by topic author JohnnyZhou
Hi JohnnyZhou,
To measure data from NI hardware with DIAdem you must define Global Virtual Channels in MAX. Only these channels will be shown in the NIDAQ dialog. In you screenshot of MAX I don’t see them.
Greetings
Walter
(983 Views)
Yes, I tried it, It works now. Thank you.
(965 Views)
