09-12-2017 10:57 PM
I'm new to DIAdem so I apologize if this is a stupid question.
I am collecting TDMS data from a test stand, with each "cycle" being a different group. I need to determine the amount of time a channel stays within range (actually two ranges, one high and one low) for each group. I need to do this automatically as there are hundreds of thousands of cycles that this operation needs to be performed on. There are a couple more operations I need to do, but they are simple enough that I think I can figure them out if I can get this one done. Anyone have any examples/advice? A sample of my data is attached if that helps...
Thanks in advance
09-14-2017 05:00 AM
Can you also attach your data file please (TDM, TDMS, CSV, ...)?
Your TDV file only describes the VIEW layout but does not contain any channel data values...
Regards
