09-03-2019 01:51 AM - edited 09-03-2019 01:52 AM
I'm sure I'm doing this horribly wrong, but I don't know really anything about the available functionality, so I'll ask here.
I'd like to know if a given Channel is monotonic.
DIAdem already displays this information in the "Other" information section, under "Monotony". I don't appear to be able to read that value as a property (it's greyed out - perhaps this has some special meaning).
A naive (working) implementation is as follows:
For Each gr In oAllGroups isMonotonic(index) = True Set oCh = gr.Channels("ChannelNameHere") Dim innerIdx, delta For innerIdx = 1 To oCh.Size-1 delta = oCh.Values(innerIdx+1) - oCh.Values(innerIdx) If delta <= 0 Then isMonotonic(index) = False End If Next Call MsgBoxDisp(isMonotonic(index)) index = index + 1 Next
but of course this is dreadfully slow (and only checks increasing monotonically - presumably the property also allows decreasing).
Probably use of a Break would speed this up (since I can stop checking once I find a step down).
Is there some built-in function that can accomplish this much more quickly?
The channel isn't evenly spaced, but it should be monotonic (so I expect in general the box to display TRUE, and the check when done in this manner to require ch.Size number of checks...)
09-03-2019 02:26 AM
If you see a property in DIAdem portal, you can drag and drop it into script to get a script line to read it.
Data.Root.ChannelGroups(1).Channels("Time").Properties("monotony").Value
The greyed out just means it is not writable.
dim chO : set chO = data.Root.ChannelGroups(1).Channels(1) Call ChnCharacter(chO) ' calculate characteristics it LogFileWrite chO.Properties("monotony").Value
ChnCharacter or ChnCharacterAll can be used to make sure that the characteristic values are calculated.
09-11-2019 05:55 AM - edited 09-11-2019 05:59 AM
'Call LogFileWrite("bChnMonotonyIsIncreasing() = " & bChnMonotonyIsIncreasing(Data.Root.ChannelGroups(1).Channels(1)))
Dim oChn
For Each oChn In Data.Root.ChannelGroups(1).Channels
Call LogFileWrite("bChnMonotonyIsIncreasing(" & oChn.Name & ") = " & bChnMonotonyIsIncreasing(Data.Root.ChannelGroups(1).Channels(1)))
Next
Function bChnMonotonyIsIncreasing(ByVal oChn)
'Returns TRUE if the monotonony of oChn is increasing.
bChnMonotonyIsIncreasing = False
If Not IsObject(oChn) Then Call Err.Raise(65535,,"ERROR - object of type channel expected")
Call ChnCharacter(oChn)
If Not oChn.Properties.Exists("monotony") Then Exit Function
If StrComp(oChn.Properties("monotony").Value,"Increasing",vbTextCompare) = 0 Then bChnMonotonyIsIncreasing = True
End Function 'bChnMonotonyIsIncreasing()
