DIAdem
DatePicker in DIAdem
Hi there,
I have worked with date picker in DIAdem 2010 versions. However am unable to get it working currently with DIAdem 2020 and above versions. I did check the forum for the same but none provided a needed solution.
Can you let me know how and which OCX to use a date / calender control currently.
Current Configuration
Windows 10 64 bit OS
DIAdem 2020 and above 64bit
Kindly let me know on the same.
Priya
(1,157 Views)
Hi Priya,
I assume that you used ActiveX controls from Microsoft? These ActiveX controls are 32-bit. You cannot use 32-bit ActiveX controls (ocx) with DIAdem 64-bit. Unfortunately, Microsoft has not updated the Common Controls to 64-bit, so they cannot be used in SUD. Unfortunately, there is no workaround here either.
Other software vendors could provide 64-Bit date time picker controls or you could implement your own ActiveX control.
I am sorry not to be able to offer a better solution at the moment.
Greetings
AnJalpaka
(1,111 Views)
