05-15-2013 12:07 PM
I have several calculations that I run on a .CSV file and the data takes a long time to load when I am running it from the reports view. If I run the same scripts manually from the script view the Dataportal does not update each line at a time but run all the calculations and then refreshes the dataportal when it is all complete is this a glitch or is there a way in the script that I can force it to only update the dataportal on completion ?
Solved! Go to Solution.
05-16-2013 11:28 AM
As far as I know data portal is only refreshed on complete if you start your script in non debug mode (Ctrl+F5)
But there is a methodto control this in your script
dim oldstate : oldstate = UIAutoRefresh UIAutoRefreshSet False ... UIAutoRefreshSet oldstate
