I build a filelist and Call DataFileImport(DataFileName, [FileImportFilter], [PartialMode]) to important it. But I do not know how to set [FileImportFilter] and [PartialMode]. The DIAdem Help does not help. My data file is attached.
PartialMode: Specifies whether the DataFileImport command displays the dialog box for channel selection. If you set this parameter on TRUE a dialog appears in which you cam specify which channels you would like to load.
With FileImportFilter you specify the kind of data format of the file you would like to load:
TDM DIAdem TDM format DD8x DIAdem DAT format asciiFilter ASCII format Excel EXCEL format LVM LabVIEW LVD format
But in your case you must use the ASCII import function with the following commands:
More in fos to the commands you find in the DIAdem help.
(Note: For DIAdem 9.1 we are working on a CSV import filter. Than it will be possible to use the following command Call DATAFILEIMPORT("TP_53_CTz10439_mh5_mh4_PHabc_0F1_103626.csv","",0))
