DIAdem
DataPlugin not showing up
So... first attempt at writing my own DataPlugin.  Done in LabVIEW using the DataPlugin SDK.
I tested it within the project it works.  Ran the installer and ran the "Register LabVIEW DataPlugin.exe" that comes with the SDK.
... it doesn't seem to work.  If I go to Settings -> Extensions -> DataPlugins... it doesn't show up in the list.  However, if I then click on "Import DataPlugin", mine shows up in the DataPlugins folder.  Not only that it has a .uri file.  If I try to import it I get a dalog box that says "You have already registered..."
What am I missing?
(3,365 Views)
Ignore this post.
I installed Diadem 64-bit then compiled a 32-bit DLL and wondered why it didn't work... Smiley Frustrated
(3,343 Views)
