DIAdem
Data portal filter behavior
Trying to use DIAdem 2022 Q4 in our company.
Compared to older versions (namely DIAdem 2017) that we've been using for many years, the channel/group filter of the data portal has a minor but annoying behavior: when trying to filter channels, the groups are not automatically expanding, see example below.
Now, we found a temporary "trick": in DIAdem general settings, you can increase the number of expanded groups when loading, for example up to 25:
In that case, and assuming your dataset has 25 groups or less, the groups will all be expanded when loading the dataset, and they will remain expanded when using the group/channel filter:
That being said, if after loading the data, you manually collapse all groups (which we typically do), the annoying behavior comes back...
DIAdem 2017 did not have this behavior. The groups were all automatically expanding when using group/channel filters.
So if you know how to replicate that behavior with DIAdem 2022 Q4, I'd appreciate the tip.
Jacques
Message 1 of 1
(651 Views)
