07-16-2019 08:01 AM
I did a install of the DIAdem 2019 software on a Win 10 laptop.
The software does not start. it hang on the splash screen "Navigator: Opening Panel"
Anyone experienced the same problem?
Kevin
07-19-2019 11:58 AM
Hi Kevin,
I haven't seen this behavior with my DIAdem also running on a Windows 10 64 bit laptop. Do you recall receiving any errors during or after the DIAdem installation?
I would try to uninstall the package from the NI Package Manager and run again the installation from the NI Package Manager. For your first installation, did you make it through the NIPM directly? or did you downloaded the package and then ran it locally with the NI Package Manager?
Warm Regards,
07-20-2019 08:46 AM
Try running DIAdem as "Administrator"... I have had problems in the past with Symantec Endpoint Protection software blocking operation as a regular user.
Regards
Peter
07-22-2019 02:12 AM
I tried through the Package Manager, the full package. Tried also version 2015, 2018, 2019.
Did the install as a domain admin. All the same result.
Kevin
07-22-2019 08:42 AM
Sorry for the confusion, I did not mean install as admin... I mean run as admin. If you select DIAdem from the menu, right click and select "more" and then select "Run as administrator".
Regards
Peter
07-23-2019 08:34 AM
Hi Peter,
Run as admin it is also not working.
I've added the National Instruments folders that are located in C:\ProgramData, C:\Program Files and C:\Program Files (x86) to the exclusion list of Windows Defender.
Still the same problem.
Kevin
08-22-2019 03:44 PM
This is strange, I am not sure why you might be getting this behavior but sounds like either software corruption or something on your computer blocking the access to the directories of the Navigator maybe, have you had other versions of DIAdem on that laptop before? or have you tried installing the same package on a different computer?
08-27-2019 02:47 PM
Kevin,
Can you confirm that you have rebooted the computer since installing DIAdem 2019?
Brad Turpin
DIAdem Product Support Engineer
02-14-2020 12:35 PM
I have the same problem. Just downloaded DIAdem 2019 SP1 for eval. Rebooted. Uninstalled and tried again. Splash screen comes up for a min or so then disappears.
System = Windows 10 Enterprise (SHB-A), 64-bit, 64GB RAM
Help!
Tommy
05-11-2020 12:44 AM - edited 05-11-2020 12:46 AM
Try to uninstall the whole NI software (Ni package manager & National instruments software) using Revo uninstaller and remove any residual files in the system C drive and then install again. I hope it will work.
