02-03-2022 02:51 AM
Hello everyone,
I've recently noticed that even though my script doesn't run all the way to the end due to an error, I can see the "The script is finished." message in the lower left corner but no error message. It is very difficult to debug my script and to find what is wrong this way.
First picture (Correct_run.png) shows the screenshot of Logfile with the correct script run. Even though we can see some errors, the script was run correctly and it produced a report.
The second picture (Run_w_error.png) shows the screenshot of Logfile, when I introduced an error into the script. There wasn't any pop-up window with an error message either.
Can anybody please help me with this issue?
My DIAdem and system info:
DIAdem - Version Information:
DIAdem 2020
Version: 20.0.0f7762
USI: 20.0.0f7736
DataFinder: 20.0.0f7748
Visual Basic Script - Information:
Script Engine Version: 5.8.7601.16982
Script Engine DLL: c:\program files\national instruments\diadem 2020\vbscript.dll
Debugger Version: 16.0.81.0
Debugger DLL: c:\windows\system32\f12\pdm.dll
System - Information:
Windows caption: Microsoft Windows 10 Enterprise
Windows: Windows (NT) 10.0.19042 (64 bit)
No. of CPUs: 12 x 2592.0 MHz (TSC)
Memory: 32092 MB (virtual 64 kB -> 131072 GB)
DIAdem: 20.0.0.7762 20060928 20060928
Language: English
Edition: Professional Edition + DAC + Crash Analysis Toolkit
05-02-2022 05:39 AM
Put these statements in the beginning of your code (or prior to where the problem exists):
CmdNoInfoDisp = False 'TRUE supresses the display of information messages. Affects ANALYSIS workspace.
CmdNoWarningDisp = False 'TRUE will allow DataFileSave() command to overwrite a file without prompting the user to verify. Also DataFileDelete()
CmdNoMsgDisp = False 'TRUE will supress the display of dialog with DataFileSave(). Also supresses MsgBoxDisp()
CmdNoDialogDisp = False
CmdNoErrorDisp = False
Call MsgBoxStateResetAll()
Search your code and any ScriptInclude() code for a "On Error Resume Next" if found, make sure a matching "On Error Goto 0" exists. Also try putting a "On Error Got 0" right before were you think the error is supposed to occur.
The script below will allow you to experiment with error supression.
This site uses cookies to offer you a better browsing experience. Learn more about our privacy statement and cookie policy.
