DIAdem
DIAdem installation error: error instalilng MSI at 'DIAdemDAC64.msi'
I'm trying to do a new install of DIAdem 2021 and am running into an error. The error states there is "An error occurred while installing the MSI at 'DIAdemDAC64.msi'. An error occurred while attempting to create the directory: C:\Users\Public\Documents\National Instruments".
I assumed everyone had access to the public folders, but I went and double checked and made sure every user and group had full control over the Public\Documents folder. I also tried running the installer both online and offline as well as running the offline installer as administrator. I then tried installing older versions of DIAdem and run into the same error. Any help would be greatly appreciated. I've attached the error log if that helps.
(1,891 Views)
I still haven't been able to resolve this. Is there any way to change the install settings so that I can install it in a different folder (i.e. not the C:\Users\Public\Documents folder)?
(1,859 Views)
Bump....Really hoping someone has a suggestion for this.
(1,796 Views)
