04-06-2018 03:52 AM
Hello Everybody,
I'm using DIAdem to evaluate my measurement data.
So if i want to plot a curve in a graph, the first curve default line-color is always red, the second green, the third blue and so on... It seems to be the sequence of the color palette in the adjustments.
Is there a opportunity to change the default sequence? e.g. that the first color is blue, the second color is green...
Thanks for the effort,
chrischros
Solved! Go to Solution.
04-06-2018 08:29 AM
Hello Chris,
From what I remember it is not possible in the settings. Which seems confirmed by the fact the this Idea Exchange is still running. Yet, that workaround might help you.
Hope it does 🙂
04-09-2018 07:50 AM
Oh nice! The workaround works quite well.
