DIAdem
DIADEM number of channels max to import
hello,
i would like to import CSV file with more than 200 columns. it seems that DIADEM accepts only 200 channels. is it the case?
how can i do to import useful channels, i tried to ignore channels and DIADEM doesn't accept that.
thank you
(1,201 Views)
Hello SED91POZ,
The DIAdem ASCII import wizard is indeed limited to 200 channels, but not DIAdem itself. In such cases you must develop the DataPlugin by yourself. You can find example in the DIAdem help.
Greetings
Walter
(1,175 Views)
OK i understand
thank you
(1,168 Views)
If your CSV file has a leading numeric channel you might be happy using the default autodetect CSV plugin that shows up in the file dialog.
(1,126 Views)
