DIAdem
DIADEM - Cross correlation for time delay
I have two identical signals.
How can I use cross correlation in DIADEM to check the time delay between the two signals?
A moving average was applied to both signals and then I used the cross correlation from the analysis option. What I got was the below figure, but I cannot figure out the amount of time delay.
(4,638 Views)
Hi Brad,
Are you using DIAdem 2015 or a previous version?  Are you able to post representative data sets that have the time shift you want to quantify?
Brad Turpin
DIAdem Product Support Engineer
(4,597 Views)
Hi Brian ,
Thanks, I have sorted out the issues as i turned the acquisition to finite.
(4,376 Views)
